Can't seem to get rid of INTMAX_MAX undeclared which shows up in ratio.h and chrono.h
Everything else looks good (so far)...
Any hints?
partial:
1>------ Build started: Project: QCC_DB_LIB, Configuration: Debug x64 ------
1> ccCameraSensor.cpp
1> ccGBLSensor.cpp
1> ccGenericPointCloud.cpp
1> ccGriddedTools.cpp
1> ccHObject.cpp
1> ccHObjectCaster.cpp
1> ccImage.cpp
1> ccIndexedTransformationBuffer.cpp
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\ratio(111): error C2065: 'INTMAX_MAX': undeclared identifier
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\ratio(123): note: see reference to class template instantiation 'std::ratio<_Nx,_Dx>' being compiled
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\ratio(113): error C2065: 'INTMAX_MAX': undeclared identifier
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\ratio(26): error C2065: 'INTMAX_MAX': undeclared identifier
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\ratio(165): note: see reference to class template instantiation 'std::_Ratio_add<_R1,_R2>' being compiled
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\ratio(216): error C2338: integer arithmetic overflow
Compile Problem Visual Studio 2015
Re: Compile Problem Visual Studio 2015
On my side (with VS 2013) INTMAX_MAX is apparently not used.
It is defined in 'stdint.h' (but in a deactivated section):
#define INTMAX_MAX INT64_MAX
INTMAX_MAX is defined in stdint.h but as Daniel said, in a deactivated section...
#if !defined(__cplusplus) || defined(__STDC_LIMIT_MACROS) //
So I added this define: __STDC_LIMIT_MACROS to the CloudCompare project properties (C++ Preprocessor Definitions)
And it compiled. Not sure why that was needed.
Thanks.
Thanks.
Hi, I resolved this issue with vs2015.
I added __STDC_LIMIT_MACROS definition to "CMakeSetCompilerOptions.cmake" file as follows.
Additionally, I added construction function to GenericIndexedCloudPersist.h file for Registration Tool functionality as follows.
add_definitions(-DNOMINMAX -D_CRT_SECURE_NO_WARNINGS [b]-D__STDC_LIMIT_MACROS[/b]).Code: Select all
class CC_CORE_LIB_API GenericIndexedCloudPersist : virtual public GenericIndexedCloud
public:
[b]GenericIndexedCloudPersist() {}[/b]
//! Default destructor
virtual ~GenericIndexedCloudPersist() {}
It took me some time but I added the same modifications to the project files.
Thanks for the feedback.
