Point cloud info in command line
Seb_B
Post by Seb_B »
Is it possible to get general info of the point cloud loaded in command line? Eg: number of points, min X, max X, min Y, max Y, ...?
Il might help to use the -CROP command after.
Thanks,
Re: Point cloud info in command line
Nope. Can you develop on this maybe? What are you willing to do exactly?
Seb_B
Post by Seb_B »
If I know the minimum and maximum in z, I would like to do "slices" of a thichness of 0.5 m (with the -crop command) each 1 meter along the z axis of my point cloud.
For my loop, I need to know the minimum and maximum in z.
Seb_B
Post by Seb_B »
Ok, not 0.5m of thichness each 1 m! This was not a good example! But somthing like thichness of 0.2 m each 1 meter.
Ok. The current version (2.6.2.beta - 'CleanMeshCutter' branch) has a new command line option that allows to apply the 'Crop' algorithm in this way (with automatic repetition, etc.). It can even start from relative coordinates (i.e. 'min' or 'max' bounding-box coordinates). The command name will be 'CROSS_SECTION' (it relies on a XML file for the parameters as it requires too much parameters/options).
So if you are able to compile this version on your side, you can take a look at the code in 'ccCommandLineParser::commandCrossSection' to figure out how it works. Otherwise you'll have to wait for the next version (with an updated documentation ;).
jason3d
Post by jason3d »
Are there any prebuilt downloads for the 2.6.2 beta?
I've just uploaded a fresh version here: http://www.cloudcompare.org/release/Clo ... in_x64.zip (EDIT: updated with the latest beta version on the 5/18).
jason3d
Post by jason3d »
Rahul
About the new beta version 2.6.2
Post by Rahul »
What are the new features you have added.
Sir you did a great job the cc software is excellent because of this software I am able to do my m.tech desertation work on Lidar.thank you ..
For proper 'release notes' you'll have to wait for the official release.
But meanwhile you can look at the 'history.txt' file next to the executable.
