Properties Window - Nowhere to be found...
jwarrick
Post by jwarrick »
Gang--
Loving CC... However, yesterday my 'Properties' window simply disappeared while I was working, and I cannot get it displayed again. This is similar to the situation that is described in the following posts:
"properties windows GONE" Postby p01ntsurf3r » Fri May 02, 2014 7:34 pm
"Properties panel missing" Postby andytrench » Fri Apr 11, 2014 12:07 pm
Yet, I do not see what the solution is for PC users. Do I need to uninstall and reinstall? Or, is there a simpler technique (such as deleting the plist file for Mac users). I am running version 2.6.1.
Thanks-- jw.
Re: Properties Window - Nowhere to be found...
You should have a 'Reset all GUI elements positions' option in the Tools menu.
If this doesn't work you can delete the two mainWindowGeometry and mainWindowState entries in the 'HKEY_CURRENT_USER/Software/CCCorp/CloudCompare' folder of the registry (simply launch regedit.exe).
jwarrick
Post by jwarrick »
Brilliant! GUI reset in the Tools worked perfectly. Thank you!
