Merge file list in batch
skarab
Postby skarab » Wed Sep 20, 2017 10:40 am
It's the my first try in batch on CC and I'm asking if it's possible to merge some files wich path is store in a .txt file.
I try the command
for /f "delims=" %%i in (Files_list.txt) do cloudcompare.exe -o %%i -merge_clouds
But it seem that it doesn't work. Files are well opened but not merged.
Do you have an idea ?
Re: Merge file list in batch
Postby daniel » Thu Sep 21, 2017 6:24 pm
Indeed, this is clearly not supported by the command line mode. You would need to be able to expand the list of filenames as a string first and then insert it in the command line (I just don't know if it's possible ;).
You need something that generates the command like this:
CloudCompare -o file1 -o file2 -o file3 -merge_clouds
DimitriDimitri
Postby DimitriDimitri » Fri Sep 22, 2017 10:03 am
Using the below command line:
CloudCompare -C_EXPORT_FMT PCD -O C:\Users\user\Desktop\ToMerge\frame_0002.pts -O C:\Users\user\Desktop\ToMerge\frame_0079.pts -MERGE_CLOUDS
Both files open correctly, but they do not merge.
Am I doing anything wrong?
Thanks!
Postby daniel » Fri Sep 22, 2017 10:08 am
Do you have a screen capture of the console output? The merge cloud should be automatically saved by default.
skarab
Postby skarab » Wed Sep 27, 2017 8:04 am
daniel wrote:You need something that generates the command like this:
You're right. I finally found with something like that. I set the -o file1 -o file2 -o file3 in a variable and i call him into the command. It work fine and it avoid me to overload my memory
framed
Postby framed » Sat Sep 30, 2017 9:55 am
Hi skarab, can you please share how you set the file name list as a variable for use in the CloudCompare command?
skarab
Postby skarab » Fri Oct 20, 2017 7:53 am
It's probably not the cleanest way but I create a .txt file with a dir and then i did this :
for /f "delims=" %%i in (%fdir%\Files_list.txt) do call :concat %%i
cloudcompare.exe %file_list% -merge_clouds -SS spatial 0.005
del %fdir%\Files_list.txt
goto :eof
:concat
set file_list=%file_list% -o %1
rem echo %file_list%
Return to “Questions”
Who is online
Users browsing this forum: Baidu [Spider] and 3 guests
cron
