Canupo train classifier from command line
Posted: Tue Oct 08, 2019 9:37 am
by juacarri
A few days ago I have discovered that it's possible to use the Canupo function from the command line of CloudCompare but, if I am not wrong, it is not possible to use the train classifier from the command line. It would be very interesting if the whole process is implemented via command line.
Re: Canupo train classifier from command line
Posted: Tue Oct 08, 2019 6:18 pm
Yes, that's not possible indeed. Mostly because this process is more 'manual' and needs some visual check. But I believe it's still possible (if someone is motivated by undertaking this task).
