Import .IFC / .RVT
Chris.
Import .IFC / .RVT
Post by Chris. »
i have a question regarding the import of .IFC or .RVT files into CloudCompare. Is there a native way to do this?
I was only able to import the files into CloudCompare using the .STL format, which requieres converting the the IFCor RVT Data into the .STL format first.
Thanks a lot!
Chris
Re: Import .IFC / .RVT
Nope, these format are not supported.
Flow
Post by Flow »
I have another question regarding .ifc formats.
Is it possible to export a mesh or the result of a RANSAC as .ifc?
thank you a lot!
Well, these formats are not supported, neither for import nor for export.
gonzalezpij
Post by gonzalezpij »
there is a plugin for reading IFC:
https://github.com/asmaloney/MeshIO
