Hi, I'm trying the "draw normals as lines" function for the first time and have been getting an error which causes a crash.
With v2.13.0 (Feb14), I compute normals on a small cloud, then click the "draw" check box.
The error that pops up is "ERROR: 3:7: 'varying' : cannot be used with a block or a structure"
followed by
"[ccGLWindow::draw3D] OpenGL error: stack underflow"
then, CC crashes.
Of the two computers I tested, it only happens on my laptop with integrated Intel Iris Graphics. Desktop with dedicated AMD GPU works fine.
Draw Normals as Lines error
Re: Draw Normals as Lines error
Ah, yes, I forgot to add a safety check: some drivers don't support the shader version used to do it. I'll add a clearer message in the next release.
Hum, it doesn't look straightforward to test the right extension that should be supported... so maybe we won't be able to improve this error message!
Zetly_Casper
Even if the error message is hard to improve, having this thread as a reference is great. It definitely saves time for those of us trying to figure out if it's a software bug or just a hardware limitation.
