I frequently use the Plane Create function.
In the Shortcut Settings, I found three different actions named “Create”, and the third one corresponds to Plane Create.
I assigned Ctrl+1 to this action, and it works correctly during the current session. However, after restarting CloudCompare, the shortcuts for all three “Create” actions become merged into the same shortcut.
As a result, the shortcut conflicts with the other “Create” actions and can no longer be used properly.
I have attached a video showing the issue.
https://youtu.be/ENWUnjwrjsY
I am currently using:
CloudCompare v2.14 beta (Sep 17, 2026)
As always, I really appreciate the work of all the developers and contributors to CloudCompare.
I would greatly appreciate it if this issue could be fixed.
Thank you!
Shortcut conflict with multiple “Create” actions after restarting CloudCompare
Re: Shortcut conflict with multiple “Create” actions after restarting CloudCompare
Hi, I created a github issue so as to give more visibility to the other CloudCompare's developers: https://github.com/CloudCompare/CloudCo ... ssues/2411
