Compilation have done successfully... but next issue:
ccViewer: error while loading shared libraries: libCC_DLL.so: cannot open shared object file: No such file or directoryCode: Select all
ccViewer: error while loading shared libraries: libCC_DLL.so: cannot open shared object file: No such file or directoryPersonally I'm far from being a Linux guru, so I won't be able to help you. Generally I try to compile on Windows and Linux but my ubuntu installation badly crashed since last "auto-update". Since then, I never found the time to re-install it...On Linux, you may encounter issues with shared libraries (.so files) if the project is not installed in /usr. In this case:
[*]either set the LD_LIBRARY_PATH variable so that it points to the qCC and ccViewer installation folders (export LD_LIBRARY_PATH=...).
[*]or call 'sudo /sbin/ldconfig -v' as suggested here
Scanning dependencies of target PclUtils
[ 70%] Building CXX object qCC/plugins/qPCL/PclUtils/CMakeFiles/PclUtils.dir/filters/MLSSmoothingUpsampling.cpp.o
In file included from /usr/include/pcl-1.6/pcl/point_types.h:301:0,
from /usr/include/pcl-1.6/pcl/point_representation.h:42,
from /usr/include/pcl-1.6/pcl/kdtree/kdtree.h:46,
from /usr/include/pcl-1.6/pcl/search/kdtree.h:43,
from /usr/include/pcl-1.6/pcl/search/pcl_search.h:44,
from /usr/include/pcl-1.6/pcl/surface/mls.h:48,
from /home/user/Desktop/trunk-master/qCC/plugins/qPCL/PclUtils/filters/dialogs/MLSDialog.h:27,
from /home/user/Desktop/trunk-master/qCC/plugins/qPCL/PclUtils/filters/MLSSmoothingUpsampling.cpp:19:
/usr/include/pcl-1.6/pcl/impl/point_types.hpp:1009:68: warning: ‘SHOT’ is deprecated [-Wdeprecated-declarations]
In file included from /usr/include/pcl-1.6/pcl/kdtree/kdtree.h:46:0,
/usr/include/pcl-1.6/pcl/point_representation.h:445:6: warning: ‘SHOT’ is deprecated (declared at /usr/include/pcl-1.6/pcl/impl/point_types.hpp:1002): USE SHOT352 FOR SHAPE AND SHOT1344 FOR SHAPE+COLOR INSTEAD [-Wdeprecated-declarations]
/usr/include/pcl-1.6/pcl/point_representation.h:446:34: warning: ‘SHOT’ is deprecated (declared at /usr/include/pcl-1.6/pcl/impl/point_types.hpp:1002): USE SHOT352 FOR SHAPE AND SHOT1344 FOR SHAPE+COLOR INSTEAD [-Wdeprecated-declarations]
/usr/include/pcl-1.6/pcl/point_representation.h:455:53: warning: ‘SHOT’ is deprecated [-Wdeprecated-declarations]
In file included from /home/user/Desktop/trunk-master/qCC/plugins/qPCL/PclUtils/filters/MLSSmoothingUpsampling.cpp:21:0:
/home/user/Desktop/trunk-master/qCC/plugins/qPCL/PclUtils/utils/filtering.hpp: In function ‘int smooth_mls(const typename pcl::PointCloud<PointInT>::Ptr&, const MLSParameters&, typename pcl::PointCloud<PointOutT>::Ptr&, pcl::PointIndicesPtr&) [with PointInT = pcl::PointXYZ, PointOutT = pcl::PointNormal, typename pcl::PointCloud<PointInT>::Ptr = boost::shared_ptr<pcl::PointCloud<pcl::PointXYZ> >, typename pcl::PointCloud<PointOutT>::Ptr = boost::shared_ptr<pcl::PointCloud<pcl::PointNormal> >, pcl::PointIndicesPtr = boost::shared_ptr<pcl::PointIndices>]’:
/home/user/Desktop/trunk-master/qCC/plugins/qPCL/PclUtils/filters/MLSSmoothingUpsampling.cpp:81:97: instantiated from here
/home/user/Desktop/trunk-master/qCC/plugins/qPCL/PclUtils/utils/filtering.hpp:263:5: error: ‘class pcl::MovingLeastSquares<pcl::PointXYZ, pcl::PointNormal>’ has no member named ‘getCorrespondingIndices’
make[2]: *** [qCC/plugins/qPCL/PclUtils/CMakeFiles/PclUtils.dir/filters/MLSSmoothingUpsampling.cpp.o] Error 1
make[1]: *** [qCC/plugins/qPCL/PclUtils/CMakeFiles/PclUtils.dir/all] Error 2
make: *** [all] Error 2
