Sorry in advance if this problem has already been mentioned, but I can't find anything about it neither on the forum nor on google.
I've just downloaded CloudCompare using snap on linux, with :
snap install cloudcompareCode: Select all
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
Qt: Session management error: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failedFurthermore, when I go in this directory and try top open in command line a .laz file :
cloudcompare -O file.lazCode: Select all
[Load] File '2010215_Helimap_SFM_M.laz' doesn't exist!Would you have an idea why this is happening?
Best regards.
EDIT : actually the folder tmp is visible, but anything that's inside it is invisible. Going inside an "invisible folder" from a browser outside CloudCompare, I tried to drag an d drop a file to CloudCompare, it also tells me the file does not exist.
EDIT2 : Converting my laz files to las format fixed the other issue of not being able to open laz files
