Missing Texture for OBJ
Authur
Post by Authur »
Hi
I compile the CloudCompare By the Code,However I found that when i load obj into my cloudcompare the obj mesh miss the Texture,However when i load the same obj to the other cloudcompare project which directly download from the github,the obj mesh has the texture.so,I want to ask that why the exture misses in my cloudcompare project.
Re: Missing Texture for OBJ
Probably because the Qt "images" plugins are not copied next to the executable. Normally, if you use the 'INSTALL' project, everything should be copied at the right place...
