Since it is confirmed it is not possible from commandline :
https://cloudcompare.org/forum/viewtopic.php?f=9&t=5363
Also since it has no parameters I think should not be too complex to add.
I Injected some cash into the project with the hope this feature could be added.
Cheers>>
comandline add HSV colors option for normals
PablerasBCN
Re: comandline add HSV colors option for normals
Ah! That's nice to support the project... but since we are doing that on our free time, it might still take some time before this is implemented ;)
PablerasBCN
I perfectly understand, no worries. As it is now CC has provided me a lot already.
This is done! I've added the -NORMALS_TO_HSV option to the command line (in the latest 2.12.alpha version).
PablerasBCN
tx so much DAniel,
I tested but I get it not to work
I tested the process manually , using menu just in case the test cloud had any type of issues but manually converts without issues.
The point cloud and the .bat that shows in the screenshot are in this zip, just update the paths
https://mega.nz/file/t1d02DCD#JruVBLJJu ... 2pdd45fnIw
In case you whan to test
Ah that's silly, because apparently it's just a wrong error message! (but still, it makes CC abandon the operation :| ).
It should be fixed normally. I updated the 2.12.alpha version (non-stereo version only for now). Can you test and confirm it works now?
PablerasBCN
FIXED!! THANKS!
