plugin accessing fileIOFilter
ankitmutha
Hi All,
I have created a plug-in that is trying to access AsciiFilter::LoadFromFile and AsciiFilter::SaveToFile methods.
However, when I compile my plug-in I get the following errors:
2>------ Build started: Project: QMOD_PLUGIN_DLL, Configuration: Debug Win32 ------
2> Creating library C:/Users/amutha/Desktop/CloudComapreVS2010/qCC/plugins/qMOD/Debug/QMOD_PLUGIN_DLLd.lib and object C:/Users/amutha/Desktop/CloudComapreVS2010/qCC/plugins/qMOD/Debug/QMOD_PLUGIN_DLLd.exp
2>MODObjectTableModel.obj : error LNK2019: unresolved external symbol "public: static enum CC_FILE_ERROR __cdecl FileIOFilter::SaveToFile(class ccHObject *,char const *,enum CC_FILE_TYPES)" (?SaveToFile@FileIOFilter@@SA?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4CC_FILE_TYPES@@@Z) referenced in function "public: void __thiscall MODObjectTableModel::saveSelectedEntities(void)" (?saveSelectedEntities@MODObjectTableModel@@QAEXXZ)
2>qMOD.obj : error LNK2019: unresolved external symbol "public: static class ccHObject * __cdecl FileIOFilter::LoadFromFile(class QString const &,enum CC_FILE_TYPES,bool,bool *,class Vector3Tpl<double> *)" (?LoadFromFile@FileIOFilter@@SAPAVccHObject@@ABVQString@@W4CC_FILE_TYPES@@_NPA_NPAV?$Vector3Tpl@N@@@Z) referenced in function "protected: void __thiscall qMOD::showFiles(class QList<class MODObject *> *)" (?showFiles@qMOD@@IAEXPAV?$QList@PAVMODObject@@@@@Z)
2>C:\Users\amutha\Desktop\CloudComapreVS2010\qCC\plugins\qMOD\Debug\QMOD_PLUGIN_DLLd.dll : fatal error LNK1120: 2 unresolved externals
I am using the latest code from github and as you can see compiling on Windows using VS2010.
My CMakeList.txt is as follows:
cmake_minimum_required(VERSION 2.8)
#REPLACE ALL 'MOD' OCCURENCES BY YOUR PLUGIN NAME
#AND ADAPT THE CODE BELOW TO YOUR OWN NEEDS!
option( INSTALL_QMOD_PLUGIN "Check to install qMOD plugin" OFF )
if (INSTALL_QMOD_PLUGIN)
#CloudCompare 'MOD' plugin
project( QMOD_PLUGIN_DLL )
#load necessary libraries (see qPCV for an example)
#if the plugin is an 'OpenGL filter', uncomment the line below
#set( CC_OPENGL_FILTER ON BOOL)
include( ../CMakePluginTpl.cmake )
#set dependencies to necessary libraries (see qPCV for an example)
target_link_libraries( ${PROJECT_NAME} ${CMAKE_CURRENT_SOURCE_DIR}/qjson/lib/qjson.lib )
include_directories( qjson/include)
include_directories( ${CMAKE_CURRENT_SOURCE_DIR} )
endif()
Can somebody provide any useful guidance for me to compile my plugin?
Regards,
Ankit
endif()
Regards,
Ankit
Re: plugin accessing fileIOFilter
You have to include the AsciiFilter.h/.cpp files in your plugin project.
Look at the qSRA plugin for instance:
Just add this under the "project( QMOD_PLUGIN_DLL )" line.
You can also replace "AsciiFilter*.h" by "*.h" if you need other file filters or if you just don't want to bother.
#need to link with AsciiFilter class
file( GLOB CC_PLUGIN_CUSTOM_HEADER_LIST ${CloudCompare_SOURCE_DIR}/fileIO/AsciiFilter*.h )
file( GLOB CC_PLUGIN_CUSTOM_SOURCE_LIST ${CloudCompare_SOURCE_DIR}/fileIO/AsciiFilter*.cpp )
ankitmutha
Thanks daniel for quick reply.
I would like to use other filters as well, so I included all the source files in fileIO folder
But I get the following errors on compilation:
Are there other files to be included?
2>VTKFilter.obj : error LNK2001: unresolved external symbol "public: static bool __cdecl ccCoordinatesShiftManager::Handle(double const *,double,bool,bool,class Vector3Tpl<double> &,double *,bool &)" (?Handle@ccCoordinatesShiftManager@@SA_NPBNN_N1AAV?$Vector3Tpl@N@@PANAA_N@Z)
2>AsciiFilter.obj : error LNK2019: unresolved external symbol "public: static bool __cdecl ccCoordinatesShiftManager::Handle(double const *,double,bool,bool,class Vector3Tpl<double> &,double *,bool &)" (?Handle@ccCoordinatesShiftManager@@SA_NPBNN_N1AAV?$Vector3Tpl@N@@PANAA_N@Z) referenced in function "public: enum CC_FILE_ERROR __thiscall AsciiFilter::loadCloudFromFormatedAsciiFile(char const *,class ccHObject &,class std::vector<struct AsciiOpenDlg::SequenceItem,class std::allocator<struct AsciiOpenDlg::SequenceItem> > const &,char,unsigned int,__int64,unsigned int,unsigned int,bool,bool *,class Vector3Tpl<double> *)" (?loadCloudFromFormatedAsciiFile@AsciiFilter@@QAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@ABV?$vector@USequenceItem@AsciiOpenDlg@@V?$allocator@USequenceItem@AsciiOpenDlg@@@std@@@std@@DI_JII_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>ObjFilter.obj : error LNK2001: unresolved external symbol "public: static bool __cdecl ccCoordinatesShiftManager::Handle(double const *,double,bool,bool,class Vector3Tpl<double> &,double *,bool &)" (?Handle@ccCoordinatesShiftManager@@SA_NPBNN_N1AAV?$Vector3Tpl@N@@PANAA_N@Z)
2>PlyFilter.obj : error LNK2001: unresolved external symbol "public: static bool __cdecl ccCoordinatesShiftManager::Handle(double const *,double,bool,bool,class Vector3Tpl<double> &,double *,bool &)" (?Handle@ccCoordinatesShiftManager@@SA_NPBNN_N1AAV?$Vector3Tpl@N@@PANAA_N@Z)
2>STLFilter.obj : error LNK2001: unresolved external symbol "public: static bool __cdecl ccCoordinatesShiftManager::Handle(double const *,double,bool,bool,class Vector3Tpl<double> &,double *,bool &)" (?Handle@ccCoordinatesShiftManager@@SA_NPBNN_N1AAV?$Vector3Tpl@N@@PANAA_N@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_write referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_close referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_write_header referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_add_obj_info referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_add_comment referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_add_list_property referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_add_scalar_property referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_add_element referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_create referenced in function "protected: enum CC_FILE_ERROR __thiscall PlyFilter::saveToFile(class ccHObject *,char const *,enum e_ply_storage_mode_)" (?saveToFile@PlyFilter@@IAE?AW4CC_FILE_ERROR@@PAVccHObject@@PBDW4e_ply_storage_mode_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_read referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_set_read_cb referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_next_obj_info referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_property_info referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_next_property referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_element_info referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_next_element referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_next_comment referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _get_plystorage_mode referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_read_header referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_open referenced in function "public: virtual enum CC_FILE_ERROR __thiscall PlyFilter::loadFile(char const *,class ccHObject &,bool,bool *,class Vector3Tpl<double> *)" (?loadFile@PlyFilter@@UAE?AW4CC_FILE_ERROR@@PBDAAVccHObject@@_NPA_NPAV?$Vector3Tpl@N@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_argument_value referenced in function "int __cdecl vertex_cb(struct t_ply_argument_ *)" (?vertex_cb@@YAHPAUt_ply_argument_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_argument_user_data referenced in function "int __cdecl vertex_cb(struct t_ply_argument_ *)" (?vertex_cb@@YAHPAUt_ply_argument_@@@Z)
2>PlyFilter.obj : error LNK2019: unresolved external symbol _ply_get_argument_property referenced in function "int __cdecl rgb_cb(struct t_ply_argument_ *)" (?rgb_cb@@YAHPAUt_ply_argument_@@@Z)
2>C:\Users\amutha\Desktop\CloudComapreVS2010\qCC\plugins\qMOD\Debug\QMOD_PLUGIN_DLLd.dll : fatal error LNK1120: 24 unresolved externalsRe: plugin accessing fileIOFilter
Almost the same thing here:
- add the ccCoordinatesShiftManager.h/.cpp files
- add the rply.h/.c files (warning the extension is '.c' here instead of '.cpp')
ankitmutha
Thanks again!
The compilation worked this time.
However the plug-in was not loaded with message:
How should I start debugging this?
[15:02:22] [Plugin] Cannot load library C:/Users/amutha/Desktop/CloudComapreVS2010/build/CloudCompare/plugins/QMOD_PLUGIN_DLL.dll: The specified module could not be found.-
ankitmutha
After reading a bit, I understand that if the plugin depends on a library (qjson in this case) and if that is not found at run time then this error is reported.
I tried to put qjson.dll in the application folder but it still did not work.
Can anyone suggest how should I actually link qjson library with my plug-in?
ankitmutha
Finally I got it working. I am using QtNetwork and I had to add that to the
Thanks again for helping out.
install_Qt_DllsRe: plugin accessing fileIOFilter
I'm glad you managed to sort that out all by yourself because I would never have guessed the 'QtNetwork' issue ;)
Is it a plugin that you'll keep on your side or do you intend to share it one day with the community? I'm just asking because of the customization of the 'install_Qt_Dlls' function. If you want to share it at some point in the future we'll have to find a cleaner way to do this.
ankitmutha
The plugin actually connects to a web application that I built to store the point cloud and mesh models. I do not think its generic enough to be useful to anyone else.
Thank you very much for the support and for your great project!
Just to warn you that with the latest trunk version (>= 2.5.3) all the I/O filters are now in a separate library (QCC_IO_LIB).
Therefore, in place of dependencies to the CloudCompare project, plugins just have to add in their CMakeList.txt file:
include_directories( ${QCC_IO_LIB_SOURCE_DIR} )
target_link_libraries( ${PROJECT_NAME} QCC_IO_LIB )
