Greetings
I am currently writing my master thesis and I use CloudCompare's Poisson Surface Reconstruction in it.
Is this plugin based in the article by M. Kazhdan and H. Hoppe?
I am asking this to know if I can cite this article in the thesis as the basis for this plugin.
Thank you for your help and for the amazing software that is cloud compare!
Re: Poisson Surface Reconstruction
Yes, this plugin directly uses the PoissonRecon library from M. Kazhdan.
So I guess you should cite their work primarily (and maybe say somewhere that you used it via CloudCompare?)
DiogoPinho
Great, thank you very much!
And yes I will not only cite the paper, but also reference the method and algorithm used in CloudCompare.
Thank you again!
Thank you again!
