Hi.
I've gotten a .bin corrupted.
I copied the file and copies ok, but same err, any way to try to have it checked or extract some work out of it?
[22:42:58] [BIN] Opening file 'E:\LIDAR_JAPAN\MMS_5_Prototype_5\MMS\temp.bin'...
[22:42:58] [BIN] Version 3.4 (coords: float / scalar: float)
[22:43:21] File seems to be corrupted
[22:43:21] Failed to read file (file position: 5844418700 / 5844418700
[22:43:21] An error occurred while loading 'temp': see console
[22:45:36] [BIN] Opening file 'E:/LIDAR_JAPAN/MMS_5_Prototype_5/MMS/temp.bin'...
[22:45:36] [BIN] Version 3.4 (coords: float / scalar: float)
[22:45:49] File seems to be corrupted
[22:45:49] Failed to read file (file position: 5844418700 / 5844418700
[22:45:49] An error occurred while loading 'temp': see console
[22:58:25] [BIN] Opening file 'E:/LIDAR_JAPAN/MMS_5_Prototype_5/MMS/temp - copia.bin'...
[22:58:25] [BIN] Version 3.4 (coords: float / scalar: float)
[22:58:45] File seems to be corrupted
[22:58:45] Failed to read file (file position: 5844418700 / 5844418700
[22:58:45] An error occurred while loading 'temp - copia': see console
corrupt .bin
Re: corrupt .bin
Indeed, it seems the file is truncated (the error happens at the very end of the file).
I guess if you are able to share the file with me ([email protected] - but it's huge!) I could try to extract something out of the file.
Re: corrupt .bin
Ok, for the records, the latest 2.14.alpha version will now give the user the choice to proceed and load the (potentially partial) clouds that CC was able to load until an issue occurred.
The caveat being that CC might crash afterwards ;)
PablerasBCN
Re: corrupt .bin
I confirm it works, TX so much Daniel.
