IT WORKS!!!!!!!
Thanks a lot you are great!
Cannot Open / Save Files MacOs
Re: Cannot Open / Save Files MacOs
Had the same issue after the update. What worked for me was giving CloudCompare full disk access in System Settings > Privacy & Security. Restarted the app after that and it could open/save files again. Worth a shot.
Am I blind or in the wrong location. I can't find Preferences:OttoBot wrote: Wed Apr 16, 2025 11:07 pm In CloudCompare, you can find the display settings by following these steps:
Open CloudCompare.
Go to the top menu and click on Edit.
From the dropdown menu, select Preferences.
Edit: Found it in Display -> Display Settings. The non-native dialog does not show my external drive, however.
I also tried giving full disk access in System Settings > Privacy & Security, but when I add CloudCompare it does not appear on the list.
I have the same problem, since the update I can't open or save anything.
I've managed to open files either by dragging directly or by deactivating ‘use native load/save dialogs’ in Display -> Display settings.
But I haven't managed to authorise access to the whole disk either, when I add cloudcompare to the list nothing happens.
Any idea where this might be coming from?
paddywhells
Thanks bjorn. That fixed it for me.
this trick works perfectly
drjasonharrison
I wasn't able to initially find this discussion,
I did find this in my console log every time I tried to do "File > Open" in Cloud Compare:
Unable to display open panel (unrecognized error: Error Domain=com.apple.ViewBridge Code=14 "(null)" UserInfo={com.apple.ViewBridge.error.hint=-[NSViewServiceMarshal bootstrap:withReply:] caught NSInvalidArgumentException '*** -[NSUserDefaults setObject:forKey:inDomain:]: domain name cannot be nil or empty' with backtrace (
"0 CoreFoundation __exceptionPreprocess + 176",
"1 libobjc.A.dylib objc_exception_throw + 88",
"2 Foundation -[NSUserDefaults(NSUserDefaults) setObject:forKey:inDomain:] + 420",
"3 AppKit +[NSOSPDefaults _readFileListModeForIdentifier:inSaveMode:inDirectory:lastListForMediaBrowserMode:] + 524",
"4 AppKit -[NSRemoteSavePanel(NSSavePanelLayout) _makeFinderKitView] + 416",
"5 AppKit -[NSRemoteSavePanel(NSSavePanelLayout) _setupFileBrowserView] + 68",
"6 AppKit -[NSRemoteSavePanel(NSSavePanelLayout) _initContentView] + 1544",
"7 AppKit -[NSRemoteSavePanel initWithContentRect:styleMask:backing:defer:] + 488",
"8 AppKit -[NSRemoteSavePanel initWithOptions:] + 476",
"9 com.apple.appkit.xpc.openAndSavePan main + 708",
"10 com.apple.appkit.xpc.openAndSavePan com.apple.appkit.xpc.openAndSavePan + 6440",
"11 AppKit -[NSViewController _loadViewIfRequired] + 72",
"12 AppKit __24-[NSViewController view]_block_invoke + 28",
"13 AppKit NSPerformVisuallyAtomicChange + 108",
"14 AppKit -[NSViewController view] + 160",
"15 ViewBridge -[NSViewServiceMarshal _bootstrap:replyData:completion:] + 1308",
"16 ViewBridge -[NSViewServiceMarshal bootstrap:withReply:] + 272",
"17 CoreFoundation __invoking___ + 148",
"18 CoreFoundation -[NSInvocation invoke] + 424",
"19 CoreFoundation -[NSInvocation invokeWithTarget:] + 64",
"20 ViewBridge -[NSVB_ViewServiceImplicitAnimationDecodingProxy forwardInvocation:] + 192",
"21 CoreFoundation ___forwarding___ + 956",
"22 CoreFoundation _CF_forwarding_prep_0 + 96",
"23 CoreFoundation __invoking___ + 148",
"24 CoreFoundation -[NSInvocation invoke] + 424",
"25 CoreFoundation -[NSInvocation invokeWithTarget:] + 64",
"26 ViewBridge -[NSVB_QueueingProxy forwardInvocation:] + 308",
"27 CoreFoundation ___forwarding___ + 956",
"28 CoreFoundation _CF_forwarding_prep_0 + 96",
"29 CoreFoundation __invoking___ + 148",
"30 CoreFoundation -[NSInvocation invoke] + 424",
"31 CoreFoundation -[NSInvocation invokeWithTarget:] + 64",
"32 CoreFoundation ___forwarding___ + 956",
"33 CoreFoundation _CF_forwarding_prep_0 + 96",
"34 CoreFoundation __invoking___ + 148",
"35 CoreFoundation -[NSInvocation invoke] + 424",
"36 ViewBridge __deferNSXPCInvocationOntoMainThread_block_invoke + 132",
"37 ViewBridge __wrapBlockWithVoucher_block_invoke + 56",
"38 ViewBridge deferredBlockOpportunity_block_invoke_2 + 356",
"39 CoreFoundation __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 28",
"40 CoreFoundation __CFRunLoopDoBlocks + 352",
"41 CoreFoundation __CFRunLoopRun + 2384",
"42 CoreFoundation CFRunLoopRunSpecific + 572",
"43 HIToolbox RunCurrentEventLoopInMode + 324",
"44 HIToolbox ReceiveNextEventCommon + 676",
"45 HIToolbox _BlockUntilNextEventMatchingListInModeWithFilter + 76",
"46 AppKit _DPSNextEvent + 684",
"47 AppKit -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688",
"48 ViewBridge __77-[NSViewServiceApplication vbNextEventMatchingMask:untilDate:inMode:dequeue:]_block_invoke + 148",
"49 ViewBridge -[NSViewServiceApplication _withToxicEventMonitorPerform:] + 152",
"50 ViewBridge -[NSViewServiceApplication vbNextEventMatchingMask:untilDate:inMode:dequeue:] + 168",
"51 ViewBridge -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 100",
"52 AppKit -[NSApplication run] + 480",
"53 AppKit NSApplicationMain + 880",
"54 libxpc.dylib _xpc_objc_main + 816",
"55 libxpc.dylib _xpc_main + 40",
"56 libxpc.dylib _xpc_copy_xpcservice_dictionary + 0",
"57 ViewBridge xpc_connection_handler + 0",
"58 ViewBridge NSViewServiceMain + 360",
"59 com.apple.appkit.xpc.openAndSavePan main + 156",
"60 dyld start + 6076"
), com.apple.ViewBridge.error.description=NSViewBridgeErrorServiceBootstrap})Re: Cannot Open / Save Files MacOs
Not sure if it's related, but have you looked at this discussion as well? https://github.com/CloudCompare/CloudCo ... ssues/2152
