CANUPO fails to separate trees from the rest properly
MaximusFuscus
Post by MaximusFuscus »
Hi, I am classifying a cloud that was acquired with aircraft in British Columbia, Canada. The area is very mountainous, it contains some steep inclines, a lake, powerlines, trees, fallen trunks + a residential area with homes, lodges, sheds, boats, fences, etc... The area is about 1.5km by 1.5km. I successfully classified the GROUND vs the rest and it worked beautifully. I selected quite a few various ground samples when training CANUPO. Then, I did a CHM with a surface raster. Then I was able to easily eliminate the lake water. After that I tried many many various forms of training in order to separate the trees (coniferous dense canopy) vs the rest. So let's say class 5 vs 6 (in this case 6 holds everything for now since CANUPO only allows 2 classes at a time). It's always removing most of the trees as I want but the bottom of some tree areas with bushes stay in class 6. Also, the powerlines mostly go to class 6 as I want it but also to class 5 (trees). I tried smaller minimum distances, large numbers of core points, whatever. Nothing seems to do the job properly. Is it possible that my samples are too large? I figured since the terrain is so varied I should have as many as possible. What do you suggest? I appreciate any answers very much as I am stuck with a project. Thank you so much.
Re: CANUPO fails to separate trees from the rest properly
Yes, there's definitely a limit to what Canupo can segment and differentiates.
Maybe it's time to step up and try 3Dmasc? I know it's more complicated, but also much more powerful.
Just my 2 cents as I'm not a user of these plugins myself ;)
MaximusFuscus
Thanks for the reply. I'm using CloudCompare 2.14, does 3DMASC work with any version? Any source of training materials for this? Thanks again.
Yes it should be included in any version above 2.13 I believe (at least on Windows).
See https://lidar.univ-rennes.fr/en/3dmasc
