when panning model how do i create that look?
Mattbro
Post by Mattbro »
Hi All,
When I am panning my model (holding down both mouse buttons and dragging) it gives my model a sort of transparent mesh look and when I release the mouse buttons it goes back to a normal shaded model. How can I retain that transparent mesh look? I need a transparent view and that appearance is perfect for what I need but I can't figure out how to maintain that look.
Thanks!!
c3kkos
Re: when panning model how do i create that look?
Post by c3kkos »
CC is decimating your cloud to have better framerate during the pan/rotate mouse operation.
If you want that look, subsample the cloud to any % you like
nicole225
Post by nicole225 »
Hello
What you're seeing is likely a temporary rendering mode that CloudCompare uses while navigating to keep performance smooth. Have you tried switching the display to wireframe or enabling transparency in the object's display settings? It won't be exactly the same as the navigation view, but it may get you very close to the look you're after.
