Hi there! I'm new to CC, but wanted to do the following from the command line on Windows:
CloudCompare -SILENT -O myfile.las -CSF -SCENES RELIEF -CLOTH_RESOLUTION 1 -CLASS_THRESHOLD 0.5 -EXPORT_GROUND
basically, I'm interested only in whatever the CSF marked as ground. The default output for qCSF is bin whenever the EXPORT_GROUND flag is raised.
However, I'd like to work with LAS files, if possible. I tried converting
CloudCompare -SILENT -O myfile.bin -C_EXPORT_FMT LAS
without luck.
I'd appreciate any help!
Thanks!
I'm new to CC
Re: I'm new to CC
Looking at the code, I think the documentation was not correct. The ground (or off-ground) points are exported as a new file, not necessarily as a bin file.
So you can use -C_EXPORT_FMT LAS before the -LAS instruction:
(and for the records, you were just missing an explicit '-SAVE_CLOUDS' instruction at the end of your second command)
CloudCompare -SILENT -O myfile.las -C_EXPORT_FMT LAS -CSF -SCENES RELIEF -CLOTH_RESOLUTION 1 -CLASS_THRESHOLD 0.5 -EXPORT_GROUNDDaniel, CloudCompare admin
