Page 2 of 2
Re: Exporting different formats results in different coordinates
Posted: Thu Jan 22, 2026 9:19 am
by c3kkos
Yes! it worked putting CC into:
C:\Users\USER\AppData\Local\Temp\CloudCompare_v2.14.beta_bin_x64
Posted: Thu Jan 22, 2026 9:22 am
by c3kkos
Uhm, scale and orientation issue still there.
Wrong scale is not a big deal anyway. easy fix
Orientation is critical
I clicked NO on both imports when asked to apply global transformations
Also tryied clicking YES at everything, resulting in .e57 point cloud traslated and nothing else.
Posted: Thu Jan 22, 2026 9:53 am
Can you give me your exact workflow?
On my side:
- I load the pts file
- I accept the default Global Shift
- save the cloud as E57
- load the E57 file
- I get the exact same points / positions
Posted: Thu Jan 22, 2026 10:48 am
by c3kkos
Workflow:
bigger point clound inside a standard, cc's .bin file.
Used X tool to slice it up, to export only the tiny slice into other software for development.
At this point i had to chose point cloud format for the other sw. it can be either .e57, las/laz OR plain ascii .pts
Decided to go with .e57
Saved slice (from cc) in .e57. Opened in other SW, noticed the misalignment.
Saved slice (from cc) in .pts. Opened in other SW, noticed everything is OK.
Opened again both files in cc shows same behaviour.
Where is the issue?
Here: I saved a point clound from cc in .e57 format and i lost original position and alignment.
saving it in .pts format is OK
Posted: Thu Jan 22, 2026 10:57 am
by c3kkos
The job is done using "CloudCompare_v2.13.2.preview_bin_x64" dated 30/06/25
Posted: Fri Jan 23, 2026 7:50 am
And have you retried the same process with the 2.14.beta version?
Also, did you rotate the large cloud prior to make a section?
Posted: Mon Jan 26, 2026 6:32 am
by c3kkos
I've rotated and traslated the original cloud, yes.
I used the default tool for manual alignment with targets within the cloud and applied the resulting transformation.
Then, i sliced up the big cloud.
I do confirm that exporting a slice in .pts and .e57 formats do produce exact results using 2.14
