Registration and Plane Fitting RMS residuals values?
ucab127
Post by ucab127 »
This question has probably been asked but I couldn't find it with a basic search.
Is there a way of extracting the residuals from the plane fitting and fine registration RMS values? I'm hoping to plot these to show the distribution of the residuals.
Many thanks
Re: Registration and Plane Fitting RMS residuals values?
Yes, once the plane is fitted, select both the plane and the source cloud and compute the distances between them (Tools > Distances > Cloud/Mesh dist).
CC will compute the distances between all points and the plane. Then select only the cloud and save it as an ASCII file. This file will contain X Y Z and the distance of each point per line. It can easily be read by another program such as Matlab or Excel.
ucab127
Post by ucab127 »
Brilliant, thank you so much!
