[M3C2] Missing plugin?
Posted: Mon Jul 13, 2015 2:15 pm
by zababa
Hello everyone! :)
I just discovered CloudCompare and with this opportunity I'd like to thank you and congratulate you on the amazing work you have done!
I am trying to compare two point clouds and extract information about the displacement field between them, so I would need the signed distance in X-Y-Z form for each point. I have come across the plugin M3C2 in other threads of this forum, but unfortunately I have not been able to find said plugin anywhere...
I am working on Linux Mint 17.2 Rafaela, compiled everything from source (acquired via git) so I have the latest version (2.6.2 beta compiled with Qt 4.8.6).
I should probably say that I don't even see the option about installing M3C2 in the ccmake configuration page, and this is what seems so strange to me.
Thank you in advance for any indications!
Re: [M3C2] Missing plugin?
Posted: Mon Jul 13, 2015 7:03 pm
Indeed, M3C2 is not yet a fully open plugin. It is kindly provided as a binary (on Windows) by Dimitri Lague's team.
The sources should be disclosed in a near future however. Meanwhile the only way to use it... is to use the Windows version.
Posted: Tue Jul 14, 2015 6:12 am
by zababa
Thank you very much for your quick reply!
I will try on a Windows machine and will keep on the lookout for when the code becomes available! :)
Posted: Tue Jul 14, 2015 7:28 am
by zababa
I'm sorry but I have another question...
I have been able to run the plugin on a Windows machine, but the distance calculated between two point clouds is still a scalar value. The only vectorial output I can see are the X-Y-Z normals, so I was thinking that perhaps the displacement field is the product of the distance and the normals, but I'm not quite sure if this is correct.
Am I missing something in the use of the plugin? Or is this the standard procedure (calculate the signed scalar distance and then multiply by the normals)?
Thanks again!
Posted: Tue Jul 14, 2015 8:12 am
Indeed, the plugin outputs the (signed) distance along the normal direction. So you could deduce the 'displacement' vector by multiplying the normal by the distance.
Posted: Tue Jul 14, 2015 1:50 pm
by zababa
Okay, thank you very much! Seems pretty good!
Posted: Wed Oct 28, 2020 9:27 pm
by ns9
Is the M3C2 plugin still only available on windows?
Posted: Fri Oct 30, 2020 5:30 pm
Not sure. Maybe it's incorporated in the latest Linux releases?
