CCLib::PointProjectionTools::computeTriangulation
Posted: Mon Mar 26, 2012 2:26 pm
I want to create a new plugin for CloudCompare. In this plugin, I would like to start with creating the triangulation of selectionned pointclouds. So I try to re-use the "MainWindow::doActionComputeMesh(CC_TRIANGULATION_TYPES type)" code.
Here is my code for the plugin.cpp:
When I try to build this code, I have the following issues:
So the issues seems to be in the classes already present in the CloudCompare sources.
For example, the first issue shows this part of code in ccLib\src\Delaunay2dMesh.cpp:
What would be the cause of these issues?
Thanks a lot for your answer.
Céline
int qPluginIGN::doAction(std::vector<ccHObject*>& selectedEntities,
unsigned& uiModificationFlags,
ccProgressDialog* progressCb,
QWidget* parent)
QString label = "Triangulation en cours...";
QProgressDialog pDlg(label, QString(), 0, 0, 0);
pDlg.show();
QApplication::processEvents();
unsigned i,selNum = selectedEntities.size();
for (i=0;i<selNum;++i)
ccHObject* ent = selectedEntities[i];
if (ent->isKindOf(CC_POINT_CLOUD))
ccGenericPointCloud* cloud = static_cast<ccGenericPointCloud*>(ent);
CC_TRIANGULATION_TYPES type = GENERIC_BEST_LS_PLANE;
CCLib::GenericIndexedMesh* dummyMesh = CCLib::PointProjectionTools::computeTriangulation(cloud,type);
if (dummyMesh)
ccMesh* mesh = new ccMesh(dummyMesh, cloud);
if (mesh)
char buffer[1024];
sprintf(buffer,"%s.mesh",cloud->getName());
mesh->setName(buffer);
mesh->setDisplay(cloud->getDisplay());
if (cloud->hasColors() && !cloud->hasNormals())
mesh->showNormals(false);
cloud->setVisible(false);
cloud->addChild(mesh);
cloud->prepareDisplayForRefresh();
//addToDB(mesh,0,false,false);
else
//ccConsole::Error("An error occured while computing mesh! (not enough memory?)");
else
//refreshAll();
//updateUI();
/*** HERE ENDS THE MAIN PLUGIN ACTION ***/
//default return code: '1' = success
return 1;
//otherwise, define you own return codes (<0 or >1) and put the corresponding
//error messages in 'getErrorMessage' (see below)
}Code: Select all
||=== qPluginIGN, debug ===|
..\..\..\CC\lib\mingw\libCC_Dlld.a(Delaunay2dMesh.o):C:\CloudCompare\CC\src\Delaunay2dMesh.cpp|89|undefined reference to `triangulate(char const*, triangulateio*, triangulateio*, triangulateio*)'|
..\..\db\lib\mingw\libqCC_dbd.a(ccMesh.o):C:\CloudCompare\qCC\db\ccMesh.cpp|1141|undefined reference to `CCLib::ManualSegmentationTools::segmentMesh(CCLib::GenericIndexedMesh*, CCLib::ReferenceCloud*, bool, CCLib::GenericProgressCallback*, CCLib::GenericIndexedCloud*, unsigned int)'|
..\..\db\lib\mingw\libqCC_dbd.a(ccPointCloud.o):C:\CloudCompare\qCC\db\ccPointCloud.cpp|1227|undefined reference to `CCLib::GeometricalAnalysisTools::computeGravityCenter(CCLib::GenericCloud*)'|
..\..\db\lib\mingw\libqCC_dbd.a(ccPointCloud.o):C:\CloudCompare\qCC\db\ccPointCloud.cpp|1872|undefined reference to `CCLib::ManualSegmentationTools::segment(CCLib::GenericIndexedCloudPersist*, float, float)'|
||=== Build finished: 5 errors, 0 warnings ===|
//on utilise la librairie "externe" Triangle
triangulateio in;
memset(&in,0,sizeof(triangulateio));
in.numberofpoints = the2dPoints.size();
in.pointlist = (REAL*)(&the2dPoints[0]);
try
triangulate("zQN",&in,&in,0);
catch (...)
//cerr << "Exception indéfinie." << endl;
return false;
Céline
