point picking tool: Points appear too big
Posted: Wed May 25, 2016 11:43 am
by Tanay
I need to measure the distances between two point clouds but the "Select 2 Points..." button in Point Picking menu plots the red coloured points, which are too big to see the actual points of clouds to be measured. I even measured the diameter of one such point and it appears to be ca. 28 mm.
How can I reduce its size? I am not able to pick the required points.
Re: point picking tool: Points appear too big
Posted: Wed May 25, 2016 7:41 pm
Can't you zoom in? The point label has a fixed size relative to the screen (not the cloud).
Posted: Tue May 31, 2016 10:41 am
by Tanay
Check these screenshots:
Image 1: with increased Default Point Size
Image 2: with decreased Default Point Size
Image 3: sometimes the red spheres appear transparent and I can see & pick up the desired points, with a bit amount of contortion. I can continue with such condition but it is not the permanent case. check earlier images; default point size in image1 and image3 is same. You can figure out the diameter of those red spheres by the distance between measured points in given clouds.
Image 4: and few rare times, its just a simple operation.
Posted: Tue May 31, 2016 12:14 pm
Weird indeed! I'll look at this asap.
Posted: Tue May 31, 2016 8:58 pm
Oh, it was in fact due to the 'perspective' mode. The closer you are from an object, the bigger it is. And this was also true for 2D label markers...
I tried to compensate for this (but it's not that easy). You can try the new beta version and give me some feedback;
http://www.cloudcompare.org/release/Clo ... bin_x64.7z
Posted: Wed Jun 08, 2016 12:48 pm
by Tanay
Thanks for the prompt action. I have used the Point Picking tool in version 2.8.0 for 63 times and it did not have same glitch.
I even changed the default point size but it was working as it supposed to be!
