I also try to install CC on a laptop with Ubuntu Xenial, on which, when configuring within cmake-gui, I ended with this error if I try to install the qPoissonrecon plugin (without it, everything runs fine) :
First this pop-up :
"Error in configuration process, project files may be invalid"
[OK]
The last two lines of the cmake-gui console :
Configuring incomplete, errors occurred!
See also "/opt/CloudCompare/trunk/build/CMakeFiles/CMakeOutput.log".
And theses lines above, in the same cmake-gui console output, are symptomatic:
Auto-add plugin subdir:/opt/CloudCompare/trunk/plugins/qPoissonRecon
CMake Error at plugins/qPoissonRecon/CMakeLists.txt:9 (add_subdirectory):
The source directory
/opt/CloudCompare/trunk/plugins/qPoissonRecon/PoissonReconLib
does not contain a CMakeLists.txt file.I wonder if there isn't any issue with the github repository cloning process?
Because on github, there is a directory called "PoissonReconLib @ 462bba4"
But on my machine, the PoissonReconLib directory is empty.
If I copy this folder manually on my machine, the config' process is running fine.
