Edit Camera Parameters [RESOLVED]
jfhullo
Post by jfhullo »
Dear Daniel,
the camera parameters for the translation (tx ty tz) does not works. In fact i,n Qt designer the properties of the boxes txLineEdit (etc.) are in a Read Only Mode. When i change it's ok to write values, but it doesnt change the parameters in fact.
Maybe the trouble comes fromthe "initFromParameters"?
See you,
JF
Re: Edit Camera Parameters
Hello JF,
this indeed only a read only value for the moment (this is rather a 'limitation' more than a bug). And moreover, the camera can't yet be 'de-centered', so the values are always (0,0,0).
This will maybe come later on! What are your needs exactly?
Daniel
jfhullo
Post by jfhullo »
Hello Daniel,
What I want to do is almost the same thing than VPO in his topic "Camera placement", to be able to defin precisly the viewpoints.
Thanks for your answer,
JF
