[SOLVED] C2C/C2M : different results if front or back view is selected
Posted: Fri Mar 31, 2017 10:07 am
I'm pretty sure this subject has already been treated but i can't find any info on the question.
My concern is about the display of cloud comparison. Here is an example :
On the left the front view of a C2M comparison of a flat object, on the right the back view (with a horizontal mirror correction).
The deformations are not really the same on both views and that can be problematic.
My workaround is to subsample the cloud until the results are similar from both view, but it can doesn't lead to the same visual quality (and the problem comes back if i select an important point size), and it is a very stochastic approach as the subsampling implies :
Is there any better/other way to correct that problem ?
I guess the software is not written to handle that problem through the 3D engine (which is totally understandable), but maybe it could be an option (a checkbox for flat objects ?) to integrate in the render to file tool ?
