error "Points must be visible"
atliagu
Post by atliagu »
Hi
I am using 2.10 alpha 64 bit version. The 3D image is a .ply file
When I try to do "Point list picking" I always get the error "Points must be visible".
Any thoughts on what I am doing wrong?
my best
Atli
Re: error "Points must be visible"
I guess that what you call "3D image" is in fact a mesh? In this case the "Point list picking" tool might not work. You have to convert the mesh to a cloud first (with Edit > Mesh > Sample points) or simply use the tool on the mesh vertices if they are dense enough (just make the 'vertices' entity brlow the mesh visible and highlight it.
atliagu
Post by atliagu »
Hi
Thanks, it is working now
my best
Atli
