CloudCompareStereo crashes on redraw()
PhilipK
Post by PhilipK »
I'm currently developing a custom plugin.
One of the implemented features is to rotate the view around the current object.
Therefore I spawn an animation-thread (new QT Thread), calculate the rotation matrix and then call the following code line (inside the animation-thread):
m_app->getActiveGLWindow()->redraw();
With standard CloudCompare (v2.10.2) the plugin works well, but with CloudCompareStereo (v2.10.2) the plugin crashes when "redraw()" is called.
Re: CloudCompareStereo crashes on redraw()
The 'stereo' version uses a quite different OpenGL context and drawing surface (to support quad buffer rendering, etc.).
I'm not sure it is safe to call 'redraw' directly in a separate thread. Can you try with a 'queued' signal? (so that the call is made from the main application thread)
PhilipK
Post by PhilipK »
I understand - thank you very much for your quick reply!
I will try out your solution and post the result here.
PhilipK
Post by PhilipK »
Thank you for your advice - finally I solved it just by calling the animation code and
within a QTimer which I started from the main Plugin thread.
