I am importing polylines with a .poly file as sets of points with a blank line between them.
X Y Z
X Y Z
X Y Z
X Y Z
X Y Z
X Y Z
X Y Z
X Y Z
X Y Z
X Y Z
Can I also encode line properties (width, color) in the file? That would be really helpful. I have too many lines to edit the properties individually after they are loaded. Or, is there another file type that I can use? I'm generating the .poly file myself in Matlab or Python.
Chris
Importing polylines with properties
Re: Importing polylines with properties
Nope, this format is super simple.
And for now it's the only 'open' format that allows to import polylines in CC. Otherwise you would have to use DXF but that's not easy to generate (and quite heavy).
phoenix_vishal
Hey,
I have a txt file of the format:
X Y Z
X Y Z
X Y Z
I force change the extension to .poly, but I get the following error: "an invalid polyline (single vertex) will be ignored"
I think I'm doing something really stupid because I'm a novice in this area. Any ideas?
Vishal
X Y Z
X Y Z
X Y Z
Vishal
Make sure there's no blank line. A blank line is interpreted as a separation between 2 polylines.
