Display Guides
bernland
Display Guides
Post by bernland »
In Photoshop, vertical and horizontal guides can be displayed:
Is there something similar in CloudCompare? Or something like an advanced bounding box with a grid-like structure?
Thank you!
Re: Display Guides
Ah, no, that's not available...
bernland
Re: Display Guides
Post by bernland »
And is there any other way to draw rectangular lines?
Re: Display Guides
So you can indeed load rectangular lines, by loading a '.poly' file. On each line, you can add a vertex. And if you add a blank line, it will create a new polyline.
So you could create a 'grid' file, by writing a file 'filename.poly':
X1 Y1 0
X2 Y1 0
X1 Y2 0
X2 Y2 0
X1 Y3 0
X2 Y3 0
X1 Y1 0
X1 YN 0
X2 Y1 0
X2 YN 0
bernland
Re: Display Guides
Post by bernland »
Excellent, thank you. That helps a lot!
