Colourise by EDL shader values?
Posted: Mon Aug 29, 2022 12:01 am
by LeeFluff
I have some colourless LiDAR data
obviously the EDL shader dramatically improves usefulness of this data for inspection purposes
Is there a way for me to edit the RGB values / overwrite these with the apparent luminance from the EDL shader ?
Re: Colourise by EDL shader values?
Posted: Thu Sep 01, 2022 9:16 pm
Sadly no...
However, the PCV plugin tries to achieve the same goal, and in a way (= as a scalar field) that allows you to change the dynamics, or to export the false colors to RGB, etc.
See https://www.cloudcompare.org/doc/wiki/i ... s_(plugin)
