Adding the ability to turn off signed distances for C2M_DIST in command line?
tbere9
Post by tbere9 »
I am trying to automate C2M distance calculations using command line, but I want the mean distances to be calculated with absolute values as positive and negative values are currently cancelling each other out. I know this is achievable by unticking the signed distances box in the C2M distance window, but there is no option for this in command line. I tried running C2C distance calculations using the mesh vertices, but the mean values are different.
Are there any workarounds for this? Is this something that might be available in the future?
Thank you :)
Re: Adding the ability to turn off signed distances for C2M_DIST in command line?
Indeed, this option is not available via the command line yet.
But we could add it of course (we just need to find the time and motivation ;).
That's you lucky day ;)
I added the -UNSIGNED sub-option to the -C2M_DIST command. You'll have to download the latest 2.13.alpha version.
tbere9
Post by tbere9 »
Thank you so much for doing that!
I downloaded and installed the 2.13.alpha, but I can't seem to get it to work for me. These are the commands I'm using to compare my STL files:
set local EnableDelayedExpansion
set Compared=C:\CC_TEST\COMP
set Reference=C:\CC_TEST\REF
for %%f in ( "%Reference%"\* ) do ("C:\Program Files\CloudCompare\CloudCompare.exe" -SILENT -O %Compared%\%%~nxf -O %Reference%\%%~nxf -C2M_DIST -UNSIGNED)
cmd /k
Am I doing something wrong?
What's the error on your side? Or do you still get signed distances?
Oh no, I realize I made a silly mistake! I'll update the code ASAP. In your current version, you can just not set the -UNSIGNED option and you'll get unsigned distances!
This will be fixed in the next release (hopefully online tomorrow).
The fixed 2.13.alpha version is now online!
