Export of points to txt, dwg
Posted: Thu Jan 12, 2023 8:14 pm
by p..
I have a question, is it possible in cloud compare to outline a broken line of a cloud of points along one of the X, Y, Z axes and then the program to mark the break points?
How can I export the points that I marked on the point cloud to txt or dwg,dxf format?
Thank you for your answer.
Re: Export of points to txt, dwg
Posted: Mon Jan 16, 2023 11:54 pm
Sorry, I'm not sure to understand...
Posted: Tue Jan 17, 2023 9:23 pm
by p..
I want to select points on the point cloud using the "Point list picking" function and then export to dxf
Posted: Sat Jan 21, 2023 10:03 am
Ah, then you have to use the 'Point list picking' tool, export the picked points as a new cloud (click on the arrow next to the floppy icon, and select 'new cloud'), and eventually select the exported cloud and save it as DXF.
