Uninstall String Registry
Brawl
Post by Brawl »
It seems that the unistallString entry created from the installer in the registry is wrong.
Value Created in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4DE0A2C8-03F9-4B3F-BAFC-1D5F2141464B}_is1: QuietUninstallString "C:\Program Files\CloudCompare\unins001.exe" /SILENT
But in %programfile% unins001 does'nt exist - > uninst000.exe is the good one.
Regards
Brawl
Re: Uninstall String Registry
Well, that's supposed to be automatically managed by Inno Setup, and on my side it's correct (unins001.exe). Do you maybe have a very old version installed?
Zetly_Casper
Post by Zetly_Casper »
I’ve seen this happen with Inno Setup before if an older installation was partially left behind or if there’s a mismatch during an overwrite. If anyone else runs into this, manually renaming the file or updating the registry path is a quick fix, but it's good to know it might just be a local fluke.
