Import ASCII files in CMD-mode (CC 2.13 beta W64bit)
Posted: Thu Sep 21, 2023 6:22 am
by DBurli
Bon jour tout les mondes
I have an ASCII file 'XYZ_RGB_01.csv' like
//X,Y,Z,Red,Green,Blue
10.001,20.001,1.001,255,255,100
10.002,30.002,2.002,100,255,100
20.003,20.003,3.003,255,100,100
... and a batch file like
"C:\Program Files\CloudCompare\CloudCompare.exe" -SILENT -C_EXPORT_FMT LAS ^
-o -GLOBAL_SHIFT 0 0 0 XYZ_RGB_01.csv ^
-AUTO_SAVE OFF -SAVE_CLOUDS FILE XYZ_RGB_01.laz
A former version of CC 2.13 alpha (2023/09/??12, W64bit) saved a correct laz file.
The actual CC 2.13 beta (2023/09/17, W64bit) saves a laz file falsified with ??missing XYZ.
As a test: I am loading this falsified file to the CC 2.13 alpha (2023/09/??12) it says 'PDAL execption: Unable to fetch data and convert as requested; Z:double(nan) - >int'
-> Question: How can I import ASCII files correctly in CC 2.13 beta in CMD-mode?
Merci beaucoup
Dan
Background: I have many *.laz generated by CC 2.13 alpha (2023/09/??12) who have RGB saved as 16 bit. RGB is not loaded as colors but as scalar fields [Red,Green,Blue] in CC 2.13 beta (2023/09/17). I recompute (e.g. x 1/256) & save these scalar fields to uint8. Then I reload the *.laz to CC 2.13 beta (2023/09/17), but scalar fields [Red,Green,Blue] are still imported as scalar fields but not as RGB-colors.
Re: Import ASCII files in CMD-mode (CC 2.13 beta W64bit)
Posted: Thu Sep 21, 2023 7:10 am
Can you share a file with us so that we can reproduce or investigate this on our side?
You can send it to [email protected]
Posted: Thu Sep 21, 2023 7:12 am
Or is the ASCII file with the 3 lines above sufficient?
Posted: Fri Sep 22, 2023 1:21 pm
by DBurli
The ASCII file with the 3 lines above is sufficient. (However, I have sent it to admin* as well.)
Notes:
The 3 points are wrongly saved with NaN-Coordinates, but with correct RGB.
Vice versa, a *.laz with three uint8 scalar fields ['Red', 'Green', 'Blue'] is not automatically RGB-colored when imported to CC 2.13 beta (2023/09/17). But in CC 2.13 alpha (2022/09/xx) this was still the case.
Posted: Sun Sep 24, 2023 6:25 pm
As discussed by email, this was due to an issue with the save dialog. Mind that right now the LAS scale will be forced to 1e-3 with the command line mode (but that should be ok for most of the vast majority of cases).
The latest 2.13.beta version is fixed and online.
Posted: Tue Sep 26, 2023 5:40 am
by DBurli
Issue is solved. Works fine. Merci beaucoup for the immediate reply and bug fixing!
