Translate-Rotate tool wait time
PablerasBCN
Post by PablerasBCN »
So, after you use the translate/rotate tool, even if you cancel the operation, there is a weird waiting time, of about 5 secs where the properties scroll bar does funny things. This wait time certainly breaks the flow when working
Re: Translate-Rotate tool wait time
Is it because it's repopulating the properties dialog? Do you have a lot of entities selected maybe?
PablerasBCN
No, only selected one element at a time.
I've noticed that in smaller files it takes less time.
I'm working in .bin files. Somewhat big 300M point scan tiles. At this point I've everything chunked in small pieces because of manual segmentation.
I'm under the impression it may be updating the properties of all elements, not only the object being moved, which usually is relatively small. few million points, if any.
