Draw Normals as Lines error
Posted: Fri Feb 16, 2024 8:09 pm
by lweidner
Hi, I'm trying the "draw normals as lines" function for the first time and have been getting an error which causes a crash.
With v2.13.0 (Feb14), I compute normals on a small cloud, then click the "draw" check box.
The error that pops up is "ERROR: 3:7: 'varying' : cannot be used with a block or a structure"
followed by
"[ccGLWindow::draw3D] OpenGL error: stack underflow"
then, CC crashes.
Of the two computers I tested, it only happens on my laptop with integrated Intel Iris Graphics. Desktop with dedicated AMD GPU works fine.
Re: Draw Normals as Lines error
Posted: Sat Feb 17, 2024 8:10 am
Ah, yes, I forgot to add a safety check: some drivers don't support the shader version used to do it. I'll add a clearer message in the next release.
Posted: Sat Feb 17, 2024 8:31 am
Hum, it doesn't look straightforward to test the right extension that should be supported... so maybe we won't be able to improve this error message!
Posted: Tue Feb 03, 2026 9:42 am
by Zetly_Casper
Even if the error message is hard to improve, having this thread as a reference is great. It definitely saves time for those of us trying to figure out if it's a software bug or just a hardware limitation.
