With the GUI it is possible to use a 'resample input cloud' option with the 'rasterize' tool (which makes it possible to subsample the cloud in a semi-gridded pattern). However this option is not mentioned in the wiki description of the corresponding -RASTERIZE command. Is there a way to use it in command line mode?
Many thanks!
resample input cloud option when using -RASTERIZE in command line mode
spiranthes
Re: resample input cloud option when using -RASTERIZE in command line mode
Oh, that was a good call: this was actually missing in the documentation, but you can use the -RESAMPLE sub-option (I've updated the wiki).
spiranthes
Fantastic, thanks a lot!
