Question about abilities of CloudCompare
yuvyuv
Post by yuvyuv »
Hello to all those comparing clouds,
I collected two point cloud streams data using two kinect devices. Now I would like to merge those into a single stream (single point cloud).
Can this be done with CloudCompare?
Thank you,
Yuv
Re: Question about abilities of CloudCompare
If these are single clouds, then you can simply select both clouds and use 'Edit > Merge'.
If they are 'steams' as in a series of clouds, then there's no automated way to 'pair' them. Maybe via the command line or via the Python interfaces.
