My problem
Posted: Sun Sep 22, 2024 11:41 am
by timfree
Grab lube and hit these live sex cams where 18+ teens fuck themselves silly with dragon dildos and MILFs milk big cocks on cam—free adult cams feed keeps loading fresh pussy every second, so click next till you find the perfect webcam model to bust to.
https://sexcamshub.cc/BellaviMur/
https://sexcamscafe.com/sexycouples35/
https://livesexcamsxxx.org/RuslanaXX/
Home alone? Same. That’s why I’m glued to this sex cams site—literally thousands of naked webcam models doing live anal, deepthroat, pussy-pump shows in open xxx chats and dirtier private rooms; tip 50 tokens and they’ll scream your handle while they cum.
Re: My problem
Posted: Sun Sep 22, 2024 3:59 pm
Well, the first part is easy with the 'File > Primitive factory' that allows you to create a sphere at a specific position (and radius).
For the camera, you can also use the 'Display > Camera settings' dialog to position and orient the camera. You can also switch the view to 'Perspective mode' so as to be able to set both a camera position, and a camera target.
However, there's no direct way to constrain the camera center on the sphere. You can pick some points on the sphere, and then manually copy these points coordinates in the camera dialog.
