Interpolate from another scalar field
stefano.ponti
Post by stefano.ponti »
Hi everyone,
in the stable version 2.13.2 i have an issue when using "interpolate from another entity" that never happened in the past. I use the tool with 2 PLY clouds having one scalar field (FLOAT) each. I create a constant SF and activate it as destination field. When the tool finishes i realize that the SF substituted the original one instead of the constant SF. In this way i can't have multiple scalar fields in the same cloud. I suppose it is a problem of floating number SF but i don't know how to add a floating number SF.
I much appreciate in advance your opinions.
Thank you very much,
Stefano
Re: Interpolate from another scalar field
Yes, when CC imports a scalar field from a cloud, it tries to create the same on the destination cloud (or it will reuse the existing one if any).
If you want to keep the one you have on the destination side, just rename it to something else first.
