Inclination from vertical
Posted: Thu Feb 06, 2025 9:22 am
by cukiii1312
I have a building and would like to visualize its wall, but with an inclination from the vertical plane. I’m looking for a visualization similar to the one in the attached photo.
Can anyone help me achieve this using CloudCompare or any other open-source software?
Thanks in advance!
Re: Inclination from vertical
Posted: Thu Feb 06, 2025 12:16 pm
So for the second images, you have several choices:
- either it's more the planarity and you can just create a vertical plane (with 'Edit > Plane > Create' for instance), and then computed the distance between the point cloud and this plane (ideally the 'Point-to-primitive distances' - see
https://www.cloudcompare.org/doc/wiki/i ... e_Distance)
- or it's also a visualization of how vertical each part of the wall is, and then you'll have to compute the point normals first, and then convert the normals to 'Dip & Dip direction' (see
https://www.cloudcompare.org/doc/wiki/i ... ection_SFs). The dip values will give you in degrees the angle to the vertical direction. See
And for the first visualization, if you have the 'dip' scalar field, you can project the points as a raster (with the 'Rasterize' tool) and even extract contour lines based on this scalar field. Don't hesitate to share the cloud with me if you need more directions (
[email protected])
But you won't be able to generate the arrows with CloudCompare.
Posted: Thu Feb 06, 2025 2:33 pm
by cukiii1312
Tnx,
I do it on the first method because I needed just verticality with just wall, not with the normals.
