Page 1 of 2
Cannot Open / Save Files MacOs
Posted: Thu Apr 03, 2025 12:11 pm
by francedc86
I just updated to MacOs 15.4 (24E248) and I cannot "Open / Save" files from Cloud Compare.
If I click the buttons nothing happen.
Any idea of how to solve?
Re: Cannot Open / Save Files MacOs
Posted: Thu Apr 03, 2025 5:25 pm
And does 'drag & drop' on the 3D view work maybe?
Posted: Mon Apr 07, 2025 10:15 pm
by Andres
I'm experiencing the same issue. I recently updated to macOS Sequoia 15.4 (24E248), and now I’m unable to open or save files using the icons or the main dropdown menu. I can still drag and drop into the 3D viewport, but without the ability to save files, I’m pretty much stuck.
Any idea if this is a bug related to macOS Sequoia 15.4 (24E248)? Or is it something I can fix on my end?
Versions used:
• CloudCompare_2.13.2_Universal
• CloudCompare_20240518_100604
Thank you!
Posted: Wed Apr 09, 2025 8:04 am
by francedc86
Hi sorry I did not see your kind reply.
Yes drag & drop works.
Open and Save buttons do not work.
Posted: Wed Apr 09, 2025 5:33 pm
by milko
I have the same problem, after the update the open and save buttons don't work, only the file drag function works.
Does anyone have any suggestions about this?
Posted: Fri Apr 11, 2025 9:26 am
by antonoio
I have the same problem. Drag and drop to import works. But saving (in another format) is not working.
macOS 15.4 CloudCompare 2.14.0
Posted: Fri Apr 11, 2025 2:20 pm
I guess this is all related to https://github.com/CloudCompare/CloudCo ... ssues/2152
Sadly, we need a macOS expert/dev to chime in...
Posted: Fri Apr 11, 2025 2:31 pm
by Ahmad Hakouk
I facing the same problems
Please help to fix it ASAP
Posted: Tue Apr 15, 2025 12:22 pm
by francedc86
Hi ok thanks.
I will follow the GitHub topic, hoping for a solution.
The problem is that using apple silicon, is not even possible to use a windows version with a vm...
Posted: Wed Apr 16, 2025 11:07 pm
by OttoBot
Hi Everyone,
I found this solution online and it seems to work
In CloudCompare, you can find the display settings by following these steps:
Open CloudCompare.
Go to the top menu and click on Edit.
From the dropdown menu, select Preferences.
In the Preferences window, look for the Display tab.
Within the Display settings, you should find the option for "Use native load/save dialog." You can disable it from there.
After making this change, try saving your files again to see if it resolves the issue.
