Mesh with texture from CloudCompare to Unity
meshtexture
Post by meshtexture »
I need your help with exporting a mesh with texture from CloudCompare to unity, it only appears grey or white even thought I tried to do it with blender or convert to RGB, I have two models to merge i unity one from reality capture and one generated by CloudCompare,
I was going through most of the questions asked and tutorials on your website but nothing seem to work,
Thank you for your help
Re: Mesh with texture from CloudCompare to Unity
How were the colors generated (or was the mesh textured when imported in CC)? And which format are you using to export the mesh?
Because some formats don't support textures, or they don't support per-vertex RGB (which is what CC is able to generate itself). And then some software tools don't manage per-vertex RGB...
meshtexture
thank you for your response, my mesh is generated with point cloud that comes from avro files, I export it in .fbx .obj and when imported to unity I can only see grey/white color
