How does align tool work ?
Posted: Thu May 15, 2025 1:32 pm
by Jean-Yves
I'm looking for documentation to understand how the “align” tool works.
On which values is the root mean square calculated?
How does it work?
Thank you in advance.
Re: How does align tool work ?
Posted: Fri May 16, 2025 5:34 pm
So the documentation is here: https://www.cloudcompare.org/doc/wiki/index.php/Align
And the RMS is simply the root of the average squared distance between every pair of points (after registration).
Posted: Mon May 19, 2025 10:00 am
by Jean-Yves
Thank you very much.
If I understand correctly, this is a 7-parameters HELMERT transformation such that the distance between each pair of points is minimised ?
Posted: Thu May 22, 2025 3:30 pm
Yes, I believe we use Umeyama's algorithm to find it.
And before we were using: 'Closed-form solution of absolute orientation using unit quaternions', B.K.P. Horn, 1987.
