"Problem with the Compass" plugin or maybe other plugins
Posted: Tue Feb 03, 2026 10:55 am
by zijian Liu
I am using the "Compass" to measure the (Dip and Dip direction) of the target, and I can see the fitted square green area in the image. However, other users seem to be able to manually add "Baecher’s disc " models with a much larger radius. How was this achieved? I tried all the tools and plugins, but couldn't find the solution. Thank you for your reply.
Re: "Problem with the Compass" plugin or maybe other plugins
Posted: Sat Feb 07, 2026 7:06 pm
Which version of CC are you using and on which OS? (you should normally press CTRL and use the mouse wheel).
