Georeferencing function
Posted: Thu Oct 08, 2026 4:45 am
I'm having some trouble understanding a georeferencing function in my point cloud software. Here's my workflow: I use surveyed ground control points with known coordinates to georeference a point cloud. After transforming and aligning the point cloud to these points, the software asks whether I want to "apply global transformation to reference points as well."
I find this question confusing. I simply want a precisely georeferenced point cloud based on my surveyed points. Typically, I select "NO—don't shift reference points." However, I once discovered my point cloud was approximately one meter off from its true position. When I reran the process and selected "YES" instead, the results were correct.
Despite this, the logic escapes me. I understand the point cloud may be slightly shifted upon import, but I don't grasp what this secondary transformation step actually does or why it matters.
Could someone clarify the difference between these two options and when each should be used?
Thank you!
Thank you!
