Sensor Decimal character [FIXED]
Posted: Mon Sep 15, 2014 5:17 pm
by jfhullo
Hi there again,
in the sensor creation or modifying windows, an error is not handled for decimal character.
If a comma is used by system, you can type positions X Y Z but CC assign then a 0 0 0. If you try to use a point as delimiter, you can't type into the textbox!
I know that an answer would be to change regional settings, but maybe CC should handle comma as well as points!
JF
Re: Sensor Decimal character
Posted: Wed Sep 17, 2014 6:25 am
Indeed. I'll fix this asap.
Posted: Wed Sep 17, 2014 7:51 pm
Ok it's fixed.
It's quite strange but it seems that Qt5 doesn't behave at all like Qt4 regarding the validation of input numbers... (and we use Qt5 since version 2.5.5).
Re: Sensor Decimal character [FIXED]
Posted: Thu Sep 18, 2014 8:45 pm
by jfhullo
Thanks Daniel !
