Bug - saving colours in LAS file
Posted: Fri Jan 26, 2024 4:04 pm
by mariolino
hi Daniel,
I want to report a bug, when a cloud has no RGB colour, and I assign it any unique colour or an HSV colour (after calculating the normals) if I try to save the LAS file the controbox RGB and the controlbox Normals(AsExtraScalarfiled) box are not activated (in the "LAS Save Options").
If instead I import a cloud with colour, delete the colour and assign a unique colour then the option to save the cloud in LAS also has the option of saving the RGB colour.
thanks
Mariolino
Re: Bug - saving colours in LAS file
Posted: Sat Jan 27, 2024 8:04 am
I can't reproduce this problem (with version 2.13.beta from the 18th of January).
Were you using an older version maybe? Maybe you can check that the 'version' and 'point format' (first tab) are sufficient to save RGB colors?
Should be at least version 1.2 and format 2 I believe.
Else, don't hesitate to send me the original file (without colors) for me to test (admin@cloudcompare.org)
Posted: Mon Jan 29, 2024 8:22 am
by mariolino
hello Daniel,
you are right! Depending on the version of the LAS file the different options are activated, in particular I was getting the default version 1.4 sub 6 which doesn't allow colour and extra field, changing to sub 7 works. I attach if needed for other users the complete table for colour, extrafield, waveform support.
Many thanks
Mariolino
Posted: Mon Jan 29, 2024 8:42 am
So by default, did CC chose the point format 6 while there were some colors on your cloud?
Posted: Wed Jan 31, 2024 12:43 pm
by mariolino
Hi Daniel
this is a cloud with assigned color inside CC. Original was 1.4 sub 6, but after addinc color don't promote to sub xx during saving with supported color.
Mariolino
Posted: Thu Feb 01, 2024 7:27 am
Thanks for the sample. That should be fixed now (https://github.com/CloudCompare/CloudCompare/pull/1950).
I'll upload a new version this week-end (or even the stable 2.13 release if everything goes as planned!)
Posted: Thu Feb 01, 2024 8:08 am
by mariolino
Many Thanks !!
Posted: Sun Feb 04, 2024 5:07 pm
I've uploaded a new 2.13.beta version online (with the fix)
Posted: Mon Feb 05, 2024 6:55 am
by mariolino
many thanks !
